To be fair to Ziegler caterpillar, they did replace the heat gauge on the first rebuild, they said that it was not working, although they didn't let me know that it was replaced. The radiator plugged was on the top side, My mistake.They will find something other than their mistake to blame this overhaul on. The radiator coolant flows from top to bottom. The seeds would be on the top. WHO overhauls and test runs a engine without a working temp gauge before it leaves? A $80 gauge could have saved the lawnmower shop 20k. They might be preparing to put some blame on you as a overheat, take caution.
Correct barrels in the pump yes, where was the timing? Nozzle size? Fuel rate? Did both pins (flywheel and pump) slide in at the same time? This is something that shoulda been done before ANYTHING came apart and documented. Dose the timing retard as the fuel rate advances? Buddy you have a frankenstein (spacer plate on a pc block) engine and a guy that has worked on a few. Id like to know what part number pistons were used and how they compare cc wise and in the dish. It will change whats going on inside the combustion chamber when you bring the science of combustion together. Good Luck...
The video of my machine running was before I took it up to Ziegler. You are right, and they are right, it wasn't working. I don't know about how they record gauge readings, I just take their word on that they ran the machine for a couple of hours, did a stall test on the machine, everything looked to be good to send out. They are going to replace #1and#6 pistons and cylinder walls.He said that they others can be cleaned up. The engine head might have to be replaced. They are going to completely inspect that too. I just have to trust them!Steve, looking at the video you posted in post #514 the temp gauge was not moving which would tell me they are right in the fact that it doesn't work. Now they told you they ran it for a couple hours and did a stall test. The mechanic should have noted that all gauges appear in the normal range. Either they lied on running it or the mechanic lied on the gauge readings. So it did not work when it left THEIR shop after THEIR overhaul. It should have been found and fixed BEFORE it left THEIR shop if the mechanic was competent.
As Doylex said, they WILL find enough wrong for you to pay for that THEIR parts in the overhaul. Zeigler will come out on top of this. Ask them to show you where ALL guage readings were recorded by the mechanic. Then show them the video that shows the gauge didn't work. Ask them how it was reading normal when it didn't work!
They said that they ran it for a couple of hours and heat gauge was normal, no load though,just stall test!HOW can you run an engine for A COUPLE OF HOURS & not check the temp?? ON A NEW ENGINE O-H!!! It DOESNT HAPPEN..
You check oil pressure & temp CONSTANTLY> thru out the run..!!!!
I don't know what else to say..
Who took the picture?51kw, do you work there?Exactly what I thought.
I can't recall that they chIf the original work they did showed scored pistons and cylinders from over heating why would they have not thoroughly inspected the cooling system? That would have been one of the first things I would have been checking!
Seems I recall they were trying to say the cylinders were scored from oiling problems do to wrong rocker assembly or some such nonsense. Last I knew oil in the valve train area does nothing for lubricating the pistons or liners. I believe myself and others raised questions about piston coolers.
This is sounding like someone cutting corners and not doing a proper repair and now looking for someone else to blame after the fact. Hard to believe if they filled the radiator and rechecked after they warmed it up they would have not noticed crap floating in there. Same as when they tore down engine there should have been signs of crap in the engine if someone was working with even one eye open!
I know our local Cat dealer will not warranty any engine overhaul with out the radiator being disassembled and cleaned by a radiator shop they approve of for that work.
I can't recall that they checked the radiator out on first rebuild. Are you saying that the wrong rocker assembly had nothing to do with the engine failure?I am thinking that the whole problem started with radiator being plugged, improper cooling of the engine.Waiting for the report on the radiator inspection. All I know is that I have had two engine failures and the mystery has not yet been solved. Thanks for your input.Being blocked that much would have been a bear to get coolant back in, shoulda been swimmers in the drains from the blockages, definite loss of concentration by someone.
This post really puzzles me. I think 51kw is really the service manager at Ziegler caterpillar and I have been talking to you all along. Sorry for negative things that I might have said!!
