NWForest
This machine operates great (except for the winch, which will be another thread for another time). There is oily dust at the bottom outside of the left final. On the phone the local Cat dealer says $3000-$7000 to either fix the seal or anything more that may be wrong in there. I am guessing the dealer is high, but either way probably not cheap to fix. This is a machine I will probably not put more than 100 hours on in the next year. 200 at the most. Mostly light road work and skidding a load or 2 of logs. As long as I keep oil in the final is this something I should really get fixed or is it likely ok to put off until if and when I am going to be using it more?
