Brian Henderson
Hello group, new to the site and in need of some help with a D5M , back story on Dozer it was run very low on oil and burned a bearing so they bought a 3116 out of a Topkick truck installed it and can't get it to run right, i was called out to work on it and so far have replaced injectors synchronized and set fuel rate and height , engine run's fairly well burning clean at idle but anything above that it produces white smoke and you can smell the fuel even burns my eyes it's so strong, set everything up to the truck engine spec.'s it has fairly good response to throttle , run's smooth just can't seem to get rid of the smoke, i know that commonly they don't put truck engines in dozers but my buddy is working on a small budget and picked up the engine for a good price, i'm just looking for some suggestions on what can be done to reduce the fuel delivery and keep the throttle response and rpm's , any help would be appreciated
