D5K2 DEF Line Retaining Clips
Hunter013
Wisconsin
Head Floor Sweeper
Cat D5K2 S/N: KY205628
On Cat SIS Group #: 399-9109
Hoses: 418-9141 and 445-4720
When we took them off the plastic retaining clips on the end of the lines, they snapped. I'm looking to see if they are offered seperate from the line, or if there is another good way to secure the lines.
JD955SC
The South
They are GM fuel line clips you can get them from NAPA or auto parts stores they are also available from the Cat dealer but my part numbers are at work and I won’t be back there until next week. Parts counter clerk will probably have a hard time finding them.
I keep a supply in my box because when I go to remove the lines it’s faster to break the cheap clip and replace.
Only available as part of the Hose Assembly unfortunately. Even looking at resources other than SIS the individual parts that make up the hose are not listed separately. It will be bought in by Cat as an assembly from an outside supplier.
Hunter013
Wisconsin
Head Floor Sweeper
I ordered some from Napa. I’ll see if they’re correct tonight.
JD955SC
The South
These are Cat part numbers for them. I just found them online from the Instagram page I originally got them from.
424-6231 Black
424-6232 White
Not listed under KY2 prefix but they are listed as separate to other hose Part Numbers for the DEF lines on other tractors such as D6K2. Weird thing is that there is no Service Mag or other document announcing their availability separate to the Hoses.
JD955SC
The South
Well now they ain’t gonna make it easy on us. And calling it a “button” of all things.
Hunter013
Wisconsin
Head Floor Sweeper
The ones from Napa worked, but I'm definitely keeping those Cat part numbers in my arsenal. Thank you everyone for the help.
