JCW
I have a D5H (Sn: 8RC05631). The 6-way blade will not lift as it should. The valve body has been rebuilt, and the problem still exists. Spools seem good and have full range of travel.
Every now and then I can tilt and/or twist then lift at the same time and it will "catch" and start to lift at almost normal speed. Blade will go down fine and lift the dozer off the ground. Tilt and twist functions work but are sometimes a bit slow, though nothing like the lift. That's the biggie.
I've done some reading on here about resolver valves. Seems like a possibility. Any thoughts? Thank you in advance for your help.
