D4h cylinder grease fittings
Discussion in 'Dozers' started by 354d, Nov 17, 2019.
  1. 354d
    354d Active Member
    Apr 13, 2009
    26
    Central Texas, USA
    This pic is of the lift cylinders on a D4h 8PB01747 . Does this require greasing? I don’t see any reference to greasing these fittings in the owner’s manual. Thanks, Carr
    DMiller likes this.
  2. Nige
    Nige Senior Member
    17,783
    I may be missing something but tare there actually grease fittings in the end of the cylinder rods.? It's hard to see from the photos whether it's a blind hole or not.
    If there are grease fittings, the frequency should be daily or every 10 operating hours whichever fits your operating regime best.
    DMiller likes this.
  3. 354d
    354d Active Member
    Apr 13, 2009
    26
    Central Texas, USA
    I can’t tell how you are supposed to grease this cylinder rod end. There are no 1/8”npt pipe threads to install a zero fitting. All of the cylinders on this dozer are set up the same way. I thought someone on this website might have a similarly equipped dozer. Thanks
  4. hosspuller
    hosspuller Senior Member
    Aug 28, 2014
    1,349
    North Carolina
    Grease fitting in the pin ???
    DMiller likes this.
  5. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    6,179
    On A Riverbank in IL. USA
    The only sure way to know if it is possible to grease them would be pull the pin and look for a hole in the bushing.
    I doubt there is one in them.
    I ran a service / lube truck many years ago and saw a lot of rod ends like that. Never worried about it needing to be greased.
    DMiller likes this.
  6. 354d
    354d Active Member
    Apr 13, 2009
    26
    Central Texas, USA
    The pins do not have a grease fitting. Thanks.
    DMiller likes this.
  7. DMiller
    DMiller Senior Member
    Feb 22, 2010
    10,306
    Almost Retired
    That Alignment hole is for Lathe Tooling centering when the shaft was built. It is not a lube point and the pins should be grease fitting equipped unless someone changed them out.
    kshansen, DB2 and GregsHD like this.
  8. Bluox
    Bluox Senior Member
    Jun 20, 2010
    988
    WA state
    That machine has 2 grease fittings on the blade and they are both on the pin that holds the blade to the C-frame and they are 50 hour fittings. I'm gonna bet they won't take grease.
    Bob
    DMiller likes this.
  9. 354d
    354d Active Member
    Apr 13, 2009
    26
    Central Texas, USA
    I will search for these grease fittings on the blade. I had hoped that the operator manual that I bought from Caterpillar would have information on these grease fittings, but it doesn’t. Thanks
  10. 354d
    354d Active Member
    Apr 13, 2009
    26
    Central Texas, USA
    Makes sense about this mystery hole.
    The pins are not equipped with grease fittings. Thanks
    DMiller likes this.
  11. kshansen
    kshansen Senior Member
    Mar 11, 2012
    9,148
    Central New York, USA
    Did some digging on SIS and it appears that there are three different cylinder arrangements most notable is the difference between the 3G9226 Chg04-05 and the 3G9226 Chg6-06. Those numbers should be on tags welded to the barrel of the cylinders.
    First is the Chg04-04:
    Note #8 Rod shows no grease fitting?
    Next is the Chg06:
    Chg06.png Note that now there is a #14 grease fitting?
    Still trying to find on SIS the C-Frame with the attaching pins for some reason I'm hitting a dead end so far.
    Not sure why it took so much digging but finally found the C-frame:
    Note that Pins #2 do not call for fittings but pin #31 has a grease fitting #34, not shown in part number list but they are there.
    Also note that when I cropped the picture of the two cylinders above I did not show the other end, but the same thing goes for that end the 04-05 cylinder does not show a grease fitting while the 06 cylinder does show a grease fitting.
    And while I getting all anal on this the cylinders that do NOT have the grease fitting use a 7J6003 bushing and the cylinders with the grease fittings use a 9T8421 bushing in both ends.
    DMiller likes this.
  12. DMiller
    Feb 22, 2010
    10,306
    Almost Retired
    Hardened sleeve bearing, polished surface minimal rotation expected type bushing. Pins would wear if are the softer material as does not rotate all that much unlike a loader or hoe. Simplifies life.
  13. 354d
    354d Active Member
    Apr 13, 2009
    26
    Central Texas, USA
    DMiller likes this.
  14. ttazzman
    ttazzman Well-Known Member
    Sep 10, 2010
    194
    missouri
    zoom in on my file picture and you will see mine(8pj01482) has a fitting on the top of the cylinder end...would be on bottom if installed upside down.. 20180724_153028.jpg
    DMiller likes this.
  15. InsleyGuy
    InsleyGuy Well-Known Member
    Jul 5, 2010
    50
    Howell, Mi
    In 1986? I got the 4th d4h sold in Michigan, 8pb00485. It had no grease fittings. They used "oil impregnated" pin bushings which turned out to be not the greatest idea. Not sure when they corrected that, probably by the series II units?
    ttazzman and DMiller like this.
