Ct Farmer
Is that water or coolant in the oil? If plain water look for rain getting in. If you are seeing steam out the stack look for bad head gasket or seal on injector holder.
If you run it at all with water/coolant in there the oil will turn to gray muck.
When my 3304 had a bad liner the coolant literally ran into the pan until the level balanced out. We took 5 gallons out when we pulledthe pan to inspect. You could pour water in the rad and watch it run through the liner. Wasn't burning it because the leak was at the base below the piston top. Block had to go to the shop for 2 lower and 3 upper inserts.
By the way if you choose to remove the pan in-frame you will need to jack the engine an inch or so out of the frame.
