Dave Neubert
Well if it is low your converter is bypassing and needs rebuilt
Hi, the inlet convertor spec is the maximum oil pressure allowed for the convertorThe pressure was low on the inlet to the TC compared to the manuals specs. In neutral, 40 psi, 1st fwd 50 psi, 2nd fwd 50 psi, 3rd fwd 75 psi, 1st rev 50 psi, 2nd rev 50 psi, 3rd rev 75 psi. None was as high as the specs, (110 +/-10 psi)
Actually all the pressure checks are done with oil at normal operating temperature .Good catch Mark. You just reminded me that the converter inlet pressure is the ONLY powertrain pressure test that is done with cold oil. In fact looking at a couple of other models the TC Inlet pressure spec is listed as "Xpsi maximum with cold oil".
