d9gdon
I'm having trouble with my D4C Series 3 SN 6YL21xx.
When I try to turn left, sometimes the right track will stop pulling. I've changed the cams, rollers, pins, and plungers(spools) in the valve bodies and adjusted the linkages according to the book but it's still not working right. It did work right when it was cold but when it warmed up it started doing it again.
I can only think that the piston that releases the steering clutch on the right side is getting pressurized oil when it shouldn't causing it to release?
