Green Valley Tailseat
I recently bought a 1940 D4-7J tail seat and am in the process of welding a cracked lower radiator tank. I figured it's the best time to also rebuild the water pump and fan pulley hub assembly and the rotted out lower radiator water tube. I bought a decal kit and paint color match sample from Antique Caterpillar Machinery Owner's Club. The decals are way off from the originals. Makes me wonder about the color match sample. i am needing help sourcing the following parts.
- fan pulley hub bearings
- water pump shaft with impeller
- water pump shaft bushings
- upper and lower radiator tank gaskets
- water pump to timing cover gasket
- thermostat gasket
- thermostat gasket
