Pulling the codes should be the first step. let us know what codes you find.
(2) Harness Code Connector
(3) Service Tool Connector (ET)
(4) Diagnostic Indicator
The service tool connector and the harness code connector are located behind the access cover for the fuse panel. The access cover is above the cab floor on the left side of the machine
To enter service mode, disconnect the machine identification plug from the harness code connector. When the control module is in the service mode the control module's diagnostics are available in order to assist with troubleshooting.
A single diagnostic code is shown. The diagnostic code is on hold. Information is shown on the diagnostic indicator by flashing the indicator ON and OFF. The flashes represent a three digit number. A series of flashes represent the first digit. A one second pause follows the first digit. Another series of flashes represents the second digit. A one second pause follows the second digit. Another series of flashes represents the third digit. Count the number of flashes. The number of flashes determine each digit. A three second pause separates each three digit number. Use table 2 in order to find the correct CID.
When you scroll through the diagnostic codes, the codes for all of the active diagnostic codes are shown one at a time. Ground connector contact 1 in order to scroll through the active diagnostic codes. Remove the ground from connector contact 1 in order to stop scrolling. The diagnostic code that is shown is now on hold. A code of 222 indicates that diagnostic codes are NOT active or logged.
Perform the procedure that corresponds to the diagnostic codes.
Clearing a diagnostic code removes the diagnostic code from the control module's memory. When a problem is corrected, it is necessary to remove the diagnostic code from the memory of the control module. The diagnostic code must be on hold in order to clear an inactive diagnostic code. The control module does not allow active diagnostic codes to be cleared.
Place the diagnostic code on hold.
The diagnostic code is on hold. Ground connector contact 3 in order to remove the logged diagnostic code from the control module's memory. The diagnostic indicator is extinguished after the inactive diagnostic code has been cleared. The diagnostic indicator is extinguished until you scroll through the diagnostic codes. The control module does not allow active diagnostic codes to be cleared.
Repeat the procedure for any remaining diagnostic codes. Return to normal mode when you are finished by replacing the machine identification plug. A diagnostic code of 222 indicates that diagnostic codes are NOT active or logged.
