PetervaldezMech
HI guy im currently working on the power train of this truck, A D250E caterpillar, serial # 5TN00683, YEAR 1996, i have checked anything that the sis told me to do in the testing & adjusting section, since i work on this truck it dont shift normal, the selector on the cabin is OK, it reads all the positions of the lever, but down on the transmission control there is a very complicated procedure that i have made several times and dont get the right set up for this linkage for the up shift and down shift control solenoids, i know that my problem is there, because i move the cam and direction and speed spools manually and it shift every gear normal but when I put the cover and all the geared control doesn't move properly and only shift to R2 to 1 and no more than that. Ex: cab lever in neutral and the trans is R2, move lever to 5 and trans is in 1st keep moving lever to other position 4,3,2,1 on the cab but with no response on the transmission.
theres some codes that i found:
im so exhausted of trying to get this truck running and kind of frustrated because i have been doing all cat refer procedures, and there is no result yet, please i really need help asap .
- 700- 7 Gear Actuator Response slow/erratic
- 700- 2 Transmission Gear Sensor : Erratic, Intermittent, or Incorrect
- 707- 5 Transmission Gear Actuator Up Solenoid : Current Below Normal
- 708- 5 Transmission Gear Actuator Down Solenoid : Current Below Normal.
