Hello all, we have a D11n #74z00648 with the 3508
Mechanical engine that has I believe a governor issue, the symptoms are lack of power and slow acceleration. We use it it for deep ripping and if you get moving and the rpms up before the ripper is lowered it seems to keep power but once it slows down enough you can feel it lose power and it won’t speed up to full rpm until you raise the ripper. I thought I found the problem and replaced the diaphragm on top of the governor with the cat rebuild kit and it ran great for a month, then same symptoms came back. Replace it again and it ran great for a few days, replaced it a third time it ran good for half a day. Finally I took out the governor diaphragm and put some oil on it and it ran great for a few hours then back to the low power if the engine is under load at low rpm. We have changed fuel filters and the transfer pump, checked fuel rail pressure. Quinn Cat came out and couldn’t help. Any suggestions would be greatly appreciated.
