I think the D series machines are all the same as far as the glass but this rig is a 2014 259d enclosed cab.
It appears that I have a rain water leak into the cab from the lowest spot on the glass window frame. Also, I don’t think the little drain hole is clogged, appears to drain water fine.
I suspect it’s a simple seal issue but it looks like a good deal of work to remove the window frame from the cab. Not a show stopper problem by any means but it’s does get old when the cab gets all musty in the heat after a little rain.
Has anyone had a similar issue and more importantly how do you remove the glass window frame (not just the sliding glass)?
The glass could really use a heaving cleaning anyway.
Thanks.
Thanks.
