Can someone here who has actually rebuilt a Cat torque converter/divider please explain how it is actually physically possible to assemble one incorrectly? They are possibly the easiest powertrain component to build and are basically just a stack-up of round things and thrust bearings. From memory, the only thing to easily get wrong is the sprag clutch and this machine doesn't have one.
The OP stated that his outlet pressure and lube pressure are within spec, so that in my estimation eliminates the sealing rings as a source of trouble.
As far as I'm concerned, an incorrectly built TQ will either lock up on the assembly bench or make metal within seconds of starting. I'm genuinely curious to hear other opinions on this.
Back to Nige's cooler theory.
