Well, I have never run a scraper before, but I have run loaders for many years, it doesn’t take much bucket angle change to go from a smooth load up, to a quick ditch! That being said, getting the cut started in clay takes a much more aggressive angle than starting in sand, but you still have to drop back on the angle, in clay, once u get the cut started. I was thinking the scraper would follow in those same foot steps? I was hoping someone had a scraper they could measure or knew where I could find a spec on it. I’m at about 10 degrees off flat right now, that looks a little much! Surely there are some blue prints somewhere with parameters?
