wrwtexan
- Joined
- Feb 5, 2011
- Messages
- 558
- Location
- Cooper, Texas
- Occupation
- Indy Farm Wrench, heavy land clearing, rancher
A customer brought me a trailered water pump powered by a Cummins B3.9-P four cylinder engine with a hole in the block by #1 rod but still running. I figured it pitched a rod but good and still had clearance to run on remaining 3. The plan was to replace engine with a long block. Not finding what I wanted, I thought about doing a rebuild and fixing the hole (weld/braze/patch with sealer) and went out for another look. Upon further inspection, it didn't pitch a rod but instead, through the hole, looks to have chucked a balancer shaft weight which went out the side! The block repair looks very feasible now but I can't at the moment find any info on the counterbalance shafts or what they will take to fix. Any experience with these?
