ktm250rider
Nope, not it or it's just not right enough. Started right up but rpms fell after about 20 min.
fuel tank vent, could i just leave the cap off to check? There are two water filters, one between the tank and pump. Now that i think about it, there is a fuel filter and water filter at the top of the engine, not sure where those feed lines are.
i replaced the lines from the tank, to the first filter and then to the lift pump. They were cracked, thought that was my problem but nope.
J303310 is the new part number it's a one piece line now.shoot, anyone got a part number for that? My manual is on my work computer and I shut it down for the week so i cant log onto it remotely. arrghhh, i almost took that stuff home too.
That's the correct number according to the Case online parts website.Is that the correct number? Cant find it online anywhere
That filter between the tank and pump could be your problem. it's a pos that will suck air even though it looks good. I trust them as far as I can throw them. If you have crap in your tank, bypass that filter with a clear inline type and run it awhile to see what you get.
The scenario given sounds a lot like bacteria growing in the tank. Look for some slime in the filters, strainers and water separators. You mention a fuel filter and I think I might have seen an in line filter in the photos. If so did you get it from an auto parts store?
