I believe all the #9s have the steel dozer style undercarriage and all the #7s are asv MTL styleJust help me understand.
The 277, 287, and 297 vs the 279, 289, and 299.... if it ends in 7, it has a completely different undercarriage than if the model number ends in 9?
And, only those that end in 9 are the ASV derived undercarriage?
Ths issue as I see it is that there is only an 8mm thick spacer listed in the Parts Manual.We have 2 -279D's. Spacers are available.
Correct. However the torsion axle design on the machines ending in 9 is an ASV derived component that may be interchangable in some applicationsJust help me understand.
Upon researching this further. Spacers are available for both 7 and 9 series machines through cat. My opinion on the availability was formed in the early days of the D series machines. I went back and reviewed some old parts manuals. The old manuals did not show spacers. At the time I sourced them through ASV for both 7 and 9 series machines. Some time since then it appears that cat has started selling the spacer for both types of undercarriages. I ran an older serial number on the electronic parts look up and it showed the spacers available.I stand corrected. Spacers may be available for your machine. On my 297 machines spacers were not available or listed in the cat books but were in ASV books.
My cat dealer can get me spacers the problem we were having is they only come in a 8mm thick version that is to be installed behind the track frames “normally #2 or #4 in the diagram” I already had these spacers on my machine I would have just bought 4 more but I only had a 6-7mm gap so if I added another 8mm spacer I worried there would be to much pressure when the track frames moved for the suspension I just machined up 4 spacers at 6.5 and the gap is basically gone and I still have space for the frames to move free on the axlesUpon researching this further. Spacers are available for both 7 and 9 series machines through cat. My opinion on the availability was formed in the early days of the D series machines. I went back and reviewed some old parts manuals. The old manuals did not show spacers. At the time I sourced them through ASV for both 7 and 9 series machines. Some time since then it appears that cat has started selling the spacer for both types of undercarriages. I ran an older serial number on the electronic parts look up and it showed the spacers available.
I agree. You likely have the best quality repair to address the wear. I believe your repair will help reduce wear.My cat dealer can get me spacers the problem we were having is they only come in a 8mm thick version that is to be installed behind the track frames “normally #2 or #4 in the diagram” I already had these spacers on my machine I would have just bought 4 more but I only had a 6-7mm gap so if I added another 8mm spacer I worried there would be to much pressure when the track frames moved for the suspension I just machined up 4 spacers at 6.5 and the gap is basically gone and I still have space for the frames to move free on the axles
Alignment seems grate track frames are straight and no strange toe in or out machine is tracking perfect aswellI agree. You likely have the best quality repair to address the wear. I believe your repair will help reduce wear.
I personally would like to see a variety of sizes available through the dealers.
Did your alignment stay true? Most of the time I have found I needed different size spacers for front versus rear axles. This may vary with the application the machine is used in?
Maybe I just found an excuse to acquire a lathe.
