southernman13
Purchased one a while back. It had been underwater and wasn’t running. I got it running and it runs good now and all functions work fine I have used it to do some clean up and it performed well. The only issue is it whines when you drive. At lower throttle is way more noticeable like it’s starving for fluid. I’ve changed the filter and can’t see where there’s any type of screen to clean. I thought about changing out the hydraulic fluid. Maybe it doesn’t have the hyguard in it and that’s the issue possibly. Idk. I haven’t done any pressure test. Like I said it rained runs and operates fine. Has plenty power and will pick up a very heavy load. I’ve never had a deere ctl or not operated one so this may be normal but it just doesn’t seem like it to me. Any opinions?
