Crusher Spares
crusher parts
  • Crusher parts products
    Votes: 0 0.0%
  • Total voters
    1
tomaschien
Loudi City
casting engineer
Crusher Spares
Crusher spares ,the other name of “crusher parts”,means all types crusher plants parts. All products have itself work life,which also suit for crusher plants. When crusher plants have problems, users have to change some parts instead of change the crusher plant. Before change the spares, first of all, users must know them and know how to exchange them.It includes jaw crusher spares,cone crusher spares and impact crusher spares.
Jaw Crusher:
As the jaw crusher structure pictures, jaw crusher spares mainly have:
Mechanical Parts. Eccentric Shaft, Balance Plate, Fly Wheel, Crusher Frame, Fixed Jaw Plate Shim, Retraction Spring, Groove Block and so on.. These parts do not need exchange very often.
Wear Casting Parts.Cheek Plate,Movable Jaw Plate,Fixed Jaw Plate,Toggle Jaw Plate, Adjust Wedge, Wedge Plate. All these parts are wear parts, which need exchange very often.Except for toggle plate, the others are manufactured by high manganese steel.
Impact Crusher:
As the impact crusher structure,it mainly has:
Mechanical Parts. Rotor,Discharge Opening,Hydraulically Operated Crusher Service Door, Impact Curtain Adjusting Rods and so on.
Wear Casting Parts. Blow bars and replaceable wear liners, which are manufactured by high chrome and need exchange regularly.
Cone Crusher :
As the cone crusher structure,it mainly has:
Mechanical Parts. There are more mechanical parts than other types. Tramp Release Assembly, Eccentric Bushing, Main Frame, Main Frame Bushing,Feed Bowl Hopper, Gear And Pinion, Counter shaft, Kinds of Bolt, Adjustment Ring ,Dust Seal Ring and so on.
Wear Casting Parts. Cone Liner and Bowl Liner. There are the regular replacement parts ,which also manufactured by high manganese,mn14,mn18 and mn22.
JYS Casting Foundry Services
JYS Casting Foundry, which specialized in casting crusher wear casting parts over 30 years, can supply customers all the types and most of brands crusher wear parts with good quality and suitable price.About us, more detail information can check in there!
crusher spares
