Im just wondering if i need to get my crank hardened, when they ground it they took 5 off the mains and 10 off the rods, he suggested getting it hardened motor is out of a komatsu pc50uu-1 3 cylinder engine, thanks for input in advance
bearing got one journal but he turned them allWas it ground due to contamination/wear or did it burn a bearing up?
Continental Engines in Memphis, TN used to do a Tuffriding process on some engine shafts we had them rebuild. Here is a link describing it.. Do not recall the deciding factor as they regularly turned Y112's and F 163's 70 10 or 20 routinely. Cost was modest and never knew good or bad from doing it.
It's a komatsu, I think it's 3d95, have go back look at model number on motorI wasn't aware you could precision harden a cast iron crankshaft. I do remember some years ago Cat called for shot peening the radius areas on the main journals of a D9 engine in some applications. Do you have a Komatsu engine or a Yanmar?
Yep I'd say they could fix u right up, for small feeI have rebuilt a wide variety of motors and have never heard of it. I would bet that if you drive downtown, simply ask some of the girls loitering around if they know of anyone that can harden your crank. I bet they might know a few people who could for a relatively good price.
Never driven a excavator 5,000 miles, that would be interestingInteresting thread. Buck knives does nitriding to there blades.
I thought the last post was a little off Kilter though. I'm paraphrasing here, seen cranks go 100,000+ miles and looked new because of the treatment. Here's a cheaper way to see the same thing, change your oil every 5,000 miles.
Not even sure what king of MPG one would get.Never driven a excavator 5,000 miles, that would be interesting
Sorry I'm late to reply but I think there is a typo there, should be GPM!Not even sure what king of MPG one would get.
took it other day, i think they told me they were going to nitride it, afraid to het it because of not knowing metal type, ill be glad get that thing back running, i miss that dirty little hoeContact Crankshaft Supply in Minneapolis. They have the capability to anneal and harden crankshafts.
