Compressor belt on an OM366
Discussion in 'Generators/Gensets' started by Frankhaddad, Aug 29, 2019.
  1. Volvomad
    Volvomad Senior Member
    Jul 14, 2011
    252
    Ireland
    Can you increase belt tension a little ?
    Is there room to put flat pulley under the flapping side , even to get a longer belt to fit the pulley in ?
    It is very tough work for 1 belt
  2. AusDave
    AusDave Senior Member
    Nov 2, 2008
    274
    Self employed
    Can you change the pulley on the compressor to a heavier one or add a steel disk to it to give more of a flywheel effect in an effort to even out the compressor pulses?
  3. Frankhaddad
    Frankhaddad Well-Known Member
    Aug 25, 2017
    53
    Maine
    The belt is a little to tight as it is, I may have room for an extra pulley, I will have to take another look at the room, very tight quarters.
  4. Frankhaddad
    Aug 25, 2017
    53
    Maine
    That is a much easier possibility, might be worth a try even if I have to have one made. I was wondering if there was a way to reduce the compression stroke of the compressor? (construction equipment experience, compressor not much) I see where you are going with pulley/flywheel effect. I did put the old pulley on the new compressor got the same results.
  5. hosspuller
    hosspuller Senior Member
    Aug 28, 2014
    1,002
    North Carolina
    You might consider a harmonic balancer instead of a simple flywheel. It would be working in reverse of usual installation on an engine. Which brings up another thought. Is the harmonic balancer on the engine doing its job?
    Tinkerer likes this.
  6. Volvomad
    Jul 14, 2011
    252
    Ireland
    I dont know anything of the science of belt tension but as I work only on the same kit over and over, i find the best tension varies hugely from 1 application to the next . If it was my machine assuming it has a good quality compressor , i would keep squeezing the belt bit by bit until it steadied or split . That is just me and I could be slated for suggesting this .
  7. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    4,284
    On A Riverbank in IL. USA
    I would be looking at the harmonic dampener on the engine. The rubber part of it may be failing. I had one that had actually allowed the pulleys and the steel weight to rotate out of alignment with the correct crankshaft position. I figured it out because the 0° timing mark was off when #1 piston was top dead center.
    I even put new timing gears in the engine before figuring it out.
