more pics
All we are doing now is manure that has gone through the separator (pic #3). The ally ways are flushed with water from a large holding cell, all the manure and water dump back into the cell and then is pumped through the separator. Most water is separated from the manure and dumped into separate holding concrete cells to settle. The manure is piled under the conveyor then taken by the loader and used to make settling ponds. Once the banks are made we pump the settled manure and water out the concrete holding cells into the portable cells. After some time to dry the loader mixes the ponds and banks together and stacks it all into a pile. All clean water goes through a system of three lagoons and is eventually used for irrigation.
All bedding is done in the winter months with straw, depending on the weather the straw gets pushed up into piles so new straw can be spread in the corrals. The haul trucks are used to haul the straw out of the corrals, the straw is piled up so it can dry out and be spread on fields. We will try the composter when the straw dries out a little, very curios on how it will work. There are always 2500-2800 cows milking plus all the young stock, dry cows etc. All manure is only from this dairy.
