Steve Bowman
It is a Waldon 7000 which specs a 14x17.5 10 ply tire size.
After picking it up recently, I have been doing some work on it to get it operational and I have not yet operated this loader. So, I don't really have a personal baseline.
Currently, it sits on solid, smooth 825-15 6.50 tires. They measure about 29" tall. My intended use is around the farm on and off gravel roads. So compared to what I have, a change back to pneumatic is the way to go
Given the fact that I have solid tires now, I will also have to source the wheels when looking for new tires.
From what I can find, the 14x17.5 tires are roughly 36" tall and I assume, 14" wide, but I am not sure.
I have found a set of 4 31x15.5-15 that look pretty good. I have also located a set of the 14x17.5 tires. Based on the pictures of both, the 31x15.5-15's look noticeably wider than the 14x17.5. I definitely like that for increased flotation. I don't plan on much road time, so I think the slightly lower gearing of the 31's won't be an issue.
Not really related to the tires themselves, but it looks like my bolt pattern and center hole are not standard skid steer dimensions, so I plan on putting new centers in the wheels also. So, any input regarding offset might be helpful. Currently, the solid wheels have about 4" to the inside, and 3" to the outside. I am thinking of trying to maintain that 3" to the outside, and let the rest go to the inside, but I might benefit from a wider stance, so I am not sure.
I can't think of any pitfalls, but thought I might just throw it out there in case there is something I am not considering.
Thanks
Thanks
