Commercial construction work pictures
Discussion in 'Jobsite Coordination' started by skyking1, Feb 24, 2021.
  1. DMiller
    DMiller Senior Member
    Feb 21, 2010
    13,199
    Kinda Retired
    They did flowable at the nuke to also receive resilience in the compacted material yet capable to dig thru, pea gravels would continue to flow on dig outs where the trench turned into a pit to retain safe working conditions. Pea Gravel pits around the site became pump station locations for ground water pumps as that became a larger looming issue.
  2. skyking1
    skyking1 Senior Member
    3,912
    yes pea gravel is a liability on a return dig. We stubbed up in a couple of places and one was abandoned below grade and noted on an as-built, so a returning plumber could hook something up without having to go down to the main line.
    DMiller and CM1995 like this.
  3. CM1995
    CM1995 Administrator
    11,479
    I need to buy a vac truck.:)
    DMiller and hvy 1ton like this.
  4. skyking1
    3,912
    no, they are a huge PITA. that was a lot of hauling off in there and two guys and a ton of moving parts to break.
    DMiller and John C. like this.
  5. CM1995
    11,479
    Actually we've kicked around the idea of a vac excavation component for our business over the last couple of years. Couple of discussions and a thread here on HEF.
    It's a huge investment with a lot of wear parts but the earning potential is there and the business model is scaleable with potential to sell to a larger company once a market share is established.
    Just thoughts at this point.
    DMiller likes this.
  6. DMiller
    Feb 21, 2010
    13,199
    Kinda Retired
    Even the little burg we live outside of has one, use to minimize disturbance of compacted soils replacing water or gas system valves. Worker said paod for itself in three years and is parked a LOT!
    CM1995 likes this.
  7. AzIron
    AzIron Senior Member
    Jun 14, 2016
    1,386
    Az
    Vac trucks are awesome but man are they a hog for maintenance I like the idea of owning one but the learning curve is steep enough with a trailer trucks a whole another ball game
    We had job that we had to protect trench integrity for a month so we backfilled with pea gravel that way when we went back we used a vacuum to suck out the gravel in no time
    DMiller likes this.
  8. skyking1
    3,912
    this was the 3rd pick in two days for the minion. It's just one of those sites.
    This is where it was sitting this morning, straddling and surrounded by trenches.
  9. skyking1
    3,912
    The minion is back on the sidewalk, having flown 6 times in and out of remote areas on the job in 4 days. I had the assistance of a great operator in the tower crane and good bellman, although I would signal the tower the old fashioned way whenever I needed to.
    Today we placed drain rock in 18" wide trenches lined with fabric, using a Gar-Bro 2 yard concrete bucket. It's touchy work, really easy to wash your fabric into the hole and make a real mess of things but it went flawlessly, due in large part to that tower operator. I'd yell out commands and the bellman stayed up top and relayed my commands to the operator.
    oarwhat and John C. like this.
  10. skyking1
    3,912
    I mobed back to that job this morning and placed 2.5 tons of pea with the concrete bucket, dumped the balance of the truckload at another site where I had robbed the site guy's pile on the weekend. Then it was back to the pit to get 2.27 tons of drain rock. It's a bugger because I have no place at all to store material on this site, nor do I have a spare machine at the yard to load from a pile so I get material in strategic amounts.
    I was aiming to get one bucket full and this is how that worked out:
    [​IMG]
    At the end of the day we hopped the mini into what real estate was available on this tight high rise site.
    [​IMG]
    Coaldust, John C. and CM1995 like this.
  11. John C.
    John C. Senior Member
    Jun 11, 2007
    11,709
    How is that 120 doing?
    skyking1 likes this.
  12. skyking1
    3,912
    I have not heard much from the new guy. It worked fine for me, much tighter now. It has always had good power and travel and swing.
    John C. likes this.
  13. skyking1
    3,912
    No pictures just all elbows today. I had no plumber or helper and dug out a Tenant Improvement (TI) in a new tilt up by myself, up and down on the machine in the ditch with shovel, broom, wheelbarrowing in the bedding because the general wanted plywood down to protect the polished floors and wheelbarrow was easier and faster than moving plywood. At least I could load it with the 18" bucket and mini.
    The 18" is a perfect normal wheelbarrow load of pea gravel. I got in 18K steps on the fitbit and a bunch of cardio.
    Then I mobed down to the hirise job, dropped off the mini, and grabbed a load of pea for the job up north, and will run there early tomorrow. GO GO GO!
    They want me to get the 20 ton tilt off that site so that will get done.
    CM1995 and Camshawn like this.
  14. skyking1
    3,912
    Randles has a mountain of quartz and granite scrap. They run it through a crusher now and then, I have not inquired about the products.
    My other materials account has recycled materials too. The current deal there is 3/4 asphalt @$6 per ton.
    CM1995 and John C. like this.
  15. CM1995
    11,479
    $6 a ton for crushed asphalt is cheap. Ordered a 25 ton load of waste rock and it was $385 delivered about 10 miles from the quarry. Cheapest rock we can get.
    We used to be able to get millings here almost free until the state and county DOT started to require all the millings be recycled and a credit back to them on the resurfacing projects. Not quite sure how it all works.
  16. John C.
    Jun 11, 2007
    11,709
    Part of my job at the last dealer I worked for was to keep the used equipment yard smoothed out so people could drive through without getting all muddy or even stuck in the winter time. One large contractor that did a lot of milling used to give us all the stuff for free. I loved that stuff. I hadn't thought about having to pay for it now.
  17. colson04
    colson04 Senior Member
    Apr 11, 2016
    1,523
    Delton, Michigan
    Same thing here. About 12 years ago, anyone could get in line for a milling project and get topped off. Now you have to be an authorized contractor with the state to haul, and everything off the mill goes to a predetermined dump site for further processing.
    When the state repaved M43 in Delton, my father in law took his dad's dump truck and hauled as many loads as he could get for his driveway. Only cost was fuel for the truck. Just pulled up in line and the miller would fill him up. Several local guys did the same.
    Camshawn, John C. and oarwhat like this.
  18. Camshawn
    Camshawn Senior Member
    Jan 25, 2017
    257
    Langley BC
    When they repaved the road here several yrs ago, there were fliers in the mailboxes and a phone call was made. Ordered 5 boxes, set up lights on the dump area, and eventually when to bed. No trucks showed. Called again and the plant decided they were close enough that they would recycle all the milling. I guess we are too close to the plant.
