k_kindig11
I recently bought a Clark TW25B 24v forklift. It has a weak battery in it and since I just use this a couple times a month at my house for 10-15min at a time, I decided I would just pull the normal 24v battery out (12-85-15 battery) And put two 8D 12v commercial batteries in series in it to create 24v. The 8D batteries are meant for combines, tractors, etc as they are 1725 amp batteries that weigh 130 pounds each. Obviously not the correct application, but in theory should work. I actually have an older 36v forklift that I use 3 of these exact batteries in and it works without issue. My dilemma is, when I hook it up to my 8D batteries in series, the lift and tilt work great, but my drive does not. It doesn’t make any sound at all. Plug it back in to the original forklift 24v battery and it works (but is really weak due to the failing battery). Why would connecting these two 12v batteries in series run the lift and tilt, but not the drive? I also went as far as using four of these batteries - two sets connected in series, then connected the sets in parallel to create 24v and double the capacity. Still same result - no drive. Any thoughts?
