kshansen
- Joined
- Mar 11, 2012
- Messages
- 11,160
- Location
- Central New York, USA
- Occupation
- Retired Mechanic in Stone Quarry
After doing some research I'm pretty sure that cylinder isn't a cat part.
Mounting is completely different.
I took a couple pics of the front cylinder and it's identical to the rear.
Has FE 777 on it?
Not sure if that means anything.
I'm still gonna try and get the repair kit for my loader.
I pretty sure the cylinders are both Clark Michigan parts.
Well I can say from working on heavy equipment for forty years that while I never worked on a Terex with air over hydraulic brakes I did see those power clusters on many Hough Loaders and even Off-Highway 65 ton Mack trucks and even a few Cat loaders. As for being Clark Michigan parts the only way they are Clark Michigan parts if Clark bought them from Wagner and put Clark Michigan labels on the boxes!
Just do like I did and open up Google and type in just FE777 and hit enter and I bet one of the top three things you will see says:
Wagner Master Cylinder Part FE777 1.75 Inch Bore No Check Valve: FE777
