Clamp-on bucket forks
Discussion in 'Tractor/Loader/Backhoes' started by syndy, May 2, 2013.
  1. syndy
    syndy Well-Known Member
    Sep 9, 2011
    160
    Retired
    North Carolina
    I found a guy selling a set of MDS clamp on forks 49" model 6000, 6000lb capacity for, asking $500. I have all sorts of use for them but started to think of the strain they would put on the hydraulics. Anyone use them, had success with them???
  2. leisureexpress
    leisureexpress Well-Known Member
    Dec 27, 2010
    137
    Utah
    Here is what I know about backhoe forks.
    Style 1 that you are looking at beats not having forks at all but the downsides are: 1) They put a lot of bending/twisting load on the bottom of the bucket. 2) the operator can not see what he's driving into/about to "spear" because the view is blocked by the bucket. 3) the load is carried out in front of the bucket which will have less leverage to lift than style 3. But an upside is they are quick attach.
    Style 2 is better than 1 because it lessens the bending/twisting load, but still, the operator can not see what you are going to drive into. Issue 3 above remains too. Another upside is they are quick attach.
    Style 3 is (in my opinion) is the best because you should be able to see the tips of the forks when approaching the item, and the lift point is closest to the machine, and you are not lifting the weight of the bucket, so you should have a higher capacity. The downside is putting one on is probably the slowest to switch over. I'm just about done making my style 3 for my backhoe.
    Style 1:
    http://www.jbcolandscape.com/Kubota-with-Paynes-Forks-Ma.jpg
    Style 2:
    http://myconstructionphotos.smugmug...ecialties/i-vVS4hvv/0/L/deere-210c_3295-L.jpg
    Style 3:
    https://www.heavyequipmentforums.com/attachment.php?attachmentid=48806&stc=1&d=1254562449
  3. trevor b
    trevor b Well-Known Member
    Aug 17, 2011
    206
    eastern ontario
    here is a pic of my home made forks with a quick- tatch IMG_0141 - Copy - Copy.jpg
  4. joe--h
    joe--h Well-Known Member
    Jul 22, 2009
    194
    Utah
    I have a set of something similar. Can't see squat. Unless you have a helper to direct you'll be on and off to see what you're doing. Better than nothing is about the best that can be said about them. Joe H
  5. heavylift
    heavylift Senior Member
    Sep 5, 2009
    1,046
    KS
    #1 is a real pain, they don't stay tight. #2 are ok #3 the better of the 3
    Cat has a set that are attached to a 4 in 1 bucket. They fold back and store on the hoe, not the best but work
  6. outbackrider
    outbackrider Well-Known Member
    Apr 28, 2012
    77
    CT
  7. syndy
    Sep 9, 2011
    160
    Retired
    North Carolina
    Thanks everyone for your input. outbackrider, I like the looks of those forks, it looks like they can be shortened by sliding them back. I have a couple of crazy ideas for fork use. One is to space them about a foot apart and slide them in and under Fraser fir trees that are about 8-12' tall and pop them out of the ground (Very shallow roots). Now I am pulling them out with a chain or using the hoe but both are slow and make a mess out of the ground. I have about 900 trees to do but I'm in no hurry.
    The other crazy is to space them 16" apart and scrape the ground to cut out a 30" deep trench. I have a foundation to dig and the other option is to get a 16" bucket. I really doubt if the fork idea would work, in sand maybe?
    This weekend I'm off to NC to get the machine up and running but the driveway and perk test are in the works this trip. I'll deal with the trees and trench ideas when I get home.
