Choice of three car haulers
Discussion in 'Trailers' started by mbavers, Apr 14, 2019.
  1. mbavers
    mbavers Well-Known Member
    Oct 11, 2011
    140
    homer alaska
    I will mostly use for supplies, lumber, etc, but will occasionally need to haul a car. I want a 16ft, 7000lb gvw (about 5200lb load), dual axle, dual brake. I have narrowed it down to: Diamond C, C&B, and PJ. They're similar, with significant differences. The PJ has the weakest looking crossmembers (2.5 X 2.5 X 3/16 angle iron, vs sturdier channels or box beams for the others. Frames are either 5" or 4" channel (I think either one would do). I can't decide, except I don't like the PJ crossmembers (too much chance for the vertical side to bend under load. Total cost, with spare, will be between $3800 and $4700, due to cost of shipping to AK. Any advice appreciated.
  2. RZucker
    RZucker Senior Member
    Jul 7, 2013
    3,593
    Mechanic/welder
    Wherever I end up
    Spend the extra grand and get the toughest one.
    DMiller likes this.
  3. NepeanGC
    NepeanGC Active Member
    Mar 19, 2017
    34
    CEO, Operator, Truck Driver, Accountant
    Ottawa, Ontario
    I've never regretted buying too sturdy of a trailer...within reason of course. Trucks gotta be able to tow it.
    Having had a couple of 3500lb axle trailers, I'd personally never get one again. I bought a 14k gvw trailer 4 years ago now, and although a bit more $$ up front, the brakes are bigger, the axles are stronger, and the tires are significantly less puncture prone. Not sure how the cdl laws are in AK, but maybe even a 10k/9900lbs, would be leaps and bounds better than a 3.5k axle setup.
    With the salt we use on the roads here, I hate trailers with box/tube structure. They always rot from the inside out. All else being equal, channel is generally my preference, stronger than angle, easy to clean and inspect, without the drawbacks of box/tubing.
    Another thing I'd look in to, being as you're on the the ocean - Does anyone sell a hot dipped galvanized trailer? They're very popular around here, and generally only costs a few bucks more than a painted trailer, but last a lot longer without all the headaches and cost of paint.
    DMiller likes this.
  4. 56wrench
    56wrench Well-Known Member
    Dec 4, 2016
    219
    alberta
    IMO any hollow or square tubing in a trailer frame is more likely to crack or break under the constant flexing and twisting. channel iron and channel iron/ angle iron or I-beam construction allows more flexing before failure.
    DMiller likes this.
  5. DMiller
    DMiller Senior Member
    Feb 22, 2010
    6,427
    Retired
    Even a Galvanized subjected to Salts will end up corrupting, anyplace the galvanized is thin will disappear quick and begin that process of decay. I liked having zinc chromate primed steel then paint over as does slow the rust process considerably but does cost considerably more. My current trailers are Channel and Angle constructs, would not have Box section frames.
  6. mbavers
    Oct 11, 2011
    140
    homer alaska
    True, but each one has it's drawbacks.
  7. mbavers
    Oct 11, 2011
    140
    homer alaska
  8. mowingman
    mowingman Senior Member
    Jul 11, 2010
    480
    north Texas
    I have an 18' Sundowner, all aluminum car trailer. I looked at the P&J and did not like them due to the reasons mentioned. I don't know anything about the other brands. However, I agree, since you are spending a lot on shipping, I would get the highest GVW you can afford right now. BTW, my aluminum trailer was about $6,000, and I pulled it home from the dealer. Glad I do not live in Alaska.
  9. mbavers
    Oct 11, 2011
    140
    homer alaska
  10. mbavers
    Oct 11, 2011
    140
    homer alaska
    I'm having trouble responding to an individual post, so apologies if this doesn't work.
    Weight is a factor, as I'm using a Tundra and live in very hilly country. I'll mostly be towing a few thousand lbs, but I might switch to load range D tires.
    I agree with box/tube; they should rustproof inside, but welding would probably ruin that anyway. I won't be using it in Winter, so salt shouldn't be a problem.
    No galvanized available and aluminum is too expensive.
    Thanks!
  11. mbavers
    Oct 11, 2011
    140
    homer alaska
    Yeah, I was hoping to get some input on brand names, but I can tell a lot by studying the construction.
    DMiller likes this.
  12. mbavers
    Oct 11, 2011
    140
    homer alaska
    Thanks.
  13. mbavers
    Oct 11, 2011
    140
    homer alaska
    Yes, I am ruling out the boxed channels.
  14. mbavers
    Oct 11, 2011
    140
    homer alaska
    I'm buying locally, so I am, in effect, paying shipping costs to the dealer. I would not buy a trailer without being to inspect it.
    I liked the PJ until I saw the angle iron crossmembers. They might figure that a car's tires are close to the crossmember attach points, so not that much bending force, but I may be loading other objects near the center, causing more stress.
    DMiller likes this.
  15. DMiller
    Feb 22, 2010
    6,427
    Retired
    My 18 footer has 3500 lb axles, four wheel brakes, built by Trailerman. Bought it decent and used for $2k, had to replace the beaten up fenders do a bit of rewire lighting bought a full set of decals so can repaint and had two bad floor boards. Trailerman is manufactured north of me by a 100 miles or so and knew how built, knew it to be a good one for my purposes.
    http://www.trailermantrailers.net/
  16. mbavers
    Oct 11, 2011
    140
    homer alaska
    Never saw one in my area.
  17. DMiller
    Feb 22, 2010
    6,427
    Retired
    Would not figure as had. Usually Local dealer sales, some in a five state area but not much further. This was as bought. Also replaced all tires just after got, six lug 15s wheels IMG_1584.JPG .
  18. mbavers
    Oct 11, 2011
    140
    homer alaska
    Looks well made. I'd guess 5" channel frame and tongue, 5 or 6 stake pockets each side.......nice.
  19. DMiller
    Feb 22, 2010
    6,427
    Retired
    Pretty handy for me, haul scrap, lumber, misc odds/ends parts/components and a few odd tractors on it from time to time.
    mbavers likes this.
  20. old-iron-habit
    old-iron-habit Senior Member
    Nov 23, 2012
    3,604
    Moose Lake, MN
    I would go with a 18 footer. With a 16 you will find yourself fighting a short trailer more often than you would like to. The extra couple ft. is cheap and invaluable when you want to stich a full bed 4 door truck on it.
    DMiller likes this.
