I read an older thread from mtrgrader that said to periodically adjust the clutch so it doesn't wear out prematurely. Grader is a 1886 730A. It has the earlier version brake and clutch that uses Dot 3 fluid. I think it might slip a little bit. The machine wants to move slightly when the clutch is fully depressed and you put it in gear. When I was doing a hard push and couldn't push any more it didn't stall. I was thinking maybe a clutch adjustment would be a good idea. The machine will usually spin the tires but not always.
