Champion 730A -96
micke
Sweden
hello, i got a champion 730 and i have some trouble, the engine is filled up with transmission oil, i have changed The transmission oil pump but the trouble remain. I need some advice. Thanx /// Micke
manitoba
Oil is probably leaking into the engine through the rear crankshaft seal. Check the drain that runs from the clutch housing to the transmission. A damaged drain could cause the clutch housing to over fill, and leak through the crank seal. Usually an overfilled clutch housing will cause some leakage out of the breather mounted on the housing. Most likely the seal just needs to be replaced
Good luck
DD
micke
Sweden
Thank you for your reply. The breather is wery clean and no oil around it. I will change the seal and tell you the result. Many thanx. /// Micke
