chain hoist
simonsrplant
Alberta CANADA
Heavy Duty Off Road RSE
A quarter ton is hardly anything, you could use a ratchet strap or similar? I carry two, a 3.5ton and 5ton. Really handy bits of kit.
mitch504
Andrews SC
I have used a Coffing brand, which is expensive, and I bought a cheap Harbor Freight one. I have had no trouble with either one.
Simonsrplant, I thought the same thing until I used one. They are handy as a shirt pocket because of how small they are. There are many components that weigh less than 500 lbs that are awkward to handle, even with a helper. think starters, pumps, driveshafts, differentials, etc. I have used a ratchet strap for these, but you have much more length of lift.
kiall1987
Scotland
Simonsrplant i have 2 of the sealey 250kg ones brilliant handy thing for holding hoses out the way suspending A pump etc
his1911
homer, ga
field service mechanic
I have s coffing. 1/2 ton that I love .its handy for rigging those smaller pieces that otherwise take 3 hands !
Randy88
iowa
Those little one's are the best invention ever, I use them all the time and never had an issue with them, I bought the cheapest one I could find at the time.
caterpillar028
ireland
HGV mechanic and fleet repairs
recently bought a 250kg tractel wll bravo leaver hoist very handy indeed used to laugh at these small hoists would have never bought one under 1 ton but i find myself using the small hoist for all kind of jobs
Slidey
The Pilbara
HD fitter
A work colleague of mine was always giving me stick about how I solved so many problems with come-a-longs as they are called here in Australia. He didnt realise how handy they were until H&S announced that you had to have a rigging ticket to use one of any size. From wresting with 2'' 6000psi hoses to nudging an engine and pto assembly the 1/4'' it needed to get the bolt holes lined up the 500kg jobbie was invaluable
kshansen
Central New York, USA
I think of my little 500lb come-a-long as the helper they have been telling me I was going to be getting about 10 years ago. That little feller will hold things for as long as needed and don't mind if I go for coffee or Pee brake!:eek:
simonsrplant
Alberta CANADA
You chaps have mentioned coffing hoists a bit...
I'm in the market to get new now, what brands do you recommend?
Always had Yale back in the UK.
As for price, if it costs an extra hundred bucks to not let me down when it's thirty below and covered in coal dust, that's fine! If you get my drift?!
norite
Sudbury, Ontario, Canada
CM (Columbus McKinnon) is the gold standard here, expensive though.
Most of the asian come a longs such as Jet work well and are small, handy and a good bang for the buck.
