Chain Grade and WLL disagreement
Jmiller26b
Missouri
I was recently talking to a friend and we couldn’t agree on what the correct way to secure a load was. On say a 12000 lb skid steer I said a grade 70 chain 3/8” and binder on each of the 4 corners. He said a grade 70 chain 3/8” and binder one on front and one on back running from side to side. I always thought the rule was secure each corner individually and to calculate the chain WLL strength by (machine operating weight/2=chain WLL needed). Please let me know what you guys think! Thanks!
I saw no mention of chaining the attachment either. I chain down loader buckets independent of the chains for the piece of equipment.
Sometimes it is just a diagonal chain, but I get it tight and it serves the purpose.
John C.
I seem to remember in years past that the hold downs in total had to be at a minimum three times the weight of the load. I don't remember any regulation that stated how or where the tie downs were done. Has that changed?
John C.
It looks like those are minimum standards and the states can modify them to require higher standards.
I have a question as to what counts as a tie down. Say someone puts a chain from one side and loops through something on a machine and down to the other side of the trailer, and then puts the binder on one side of the chain, does that count as two points of tie down?
The Peej
Connecticut
No that is one anchor point but you will get credit for the full strength of the chain, chaining direct you only get 50%
Tyler d4c
Salix Pa
The right ways to the best of my knowledge is one on each corner and one on the attachment. Aka two on the the back 2 on the bucket for this example here.
I use a single 20' 3/8" chain on the front of the 120 excavator, but use each end of it independently to cross-chain the tracks with two ratchet binders. Forces are in, forward, and down.
I added tie down loops to the top corners of the frame at the rear location for the track, and pull it in, back, and down there with short pieces of 3/8" and ratchets, then i chain down the arm/bucket at the crook of the bucket. Forces are down and back on the bucket. I just chained it down today to mobilize to a new job, but did not think it through. I had a phone malfunction and did not get with the plumber first. i got down there and everyone had left early for the long weekend so I got to drag it back up hill to the shop till Tuesday ( DOH!)
All loaded up and the gate was locked, DOH!
Cheap "old" Geezer
I default to excess, If ONE chain at each end is prescribed I will use two. Was in flatbed trucking for a few years where we were tasked to tie down severe loads accorded by client patterns and quantities, roll steel set 'suicide ' generally called for 6 1/2" chains and ratchet binders as well as significant cribbing, three each direction. Situated 'Roll Over', received 8 of same where we oft defaulted to 8 either way. Machinery is still tied down by myself with separate chains and binders to each of four corners, if requirement is two at each corner then are still all separate devices.
suladas
Curious how those cross chains would compare to going to inside of pads to outside of frame rail, I would think with the chain so long it wouldn't be nearly as good? I go inside of pads to outside of frame on each corner of 210, 5/8" chains. Don't chain down the arm/bucket, technically you're suppose to here no one does and never been stopped it's really a waste of time unless you need the WLL, only time I do is if I have another attachment in the bucket.
I chain tracks to pull in every time.
I got a freebie from the county sheriff one day. He said he was waiting for me to roll with my backhoe with no chain on the bucket, so he could write me up. Ever since I chain anything that can move.
Cheap "old" Geezer
Twehous did not secure the mast root on the American crane they dumped on the highway
They were fined here for the incident and are now tying down as required. They are still hauling as is their big money business.
Old Doug
Mo
Tags
Connecticut
That answered some ??? but at one time every one was net rapping junk cars. If the cars are not crushed but stacked 2 high do i steal need rap? I have been chaining the top cars with 4 chains and the bottom with 2 chains. Some times i use 10 or 12 chains on 3 cars thats alot of chains.
It does seem like a lot of chains, but I'm sure it's a case of rather being safe than sorry? Plus, cars tend to bounce around a bunch if you don't have them cinched way down. I see a lot of the junk car guys by me throwing nets or tarps over the cars after they've been crushed
