Hamza@1997
Hi;
My name is Hamza, and I am working as an automobile engineer in a reputed truck company that makes commercial vehicles.
Currently, I am working on catterpillar-based transmission ( Cat CX28). Whenever I shift from high to low, the speedometer does not give an accurate value. We found out that we wired the transfer case in the wrong way. Using the cat's official wiring, we corrected the wiring of the transmission to the transfer case.
However, still, with the new wiring, our speedometer is not correct. We took the help of CAT ET ( Electronic Technician). I found out that there is a switch that is not available. The name of that switch is the low Range sense switch. CAT ET shows that this switch is unavailable.
I believe that the low range sense switch is actually a detent switch (The detent switch is mentioned in the CAT wiring diagram).
The detent switch is working as it should. It basically shorts the two terminals, and lets transmission know that the LOW range has been engaged. But, still, our speedometer is not correct and the smart low-range indicator is not working.
If there is any CAT expert, please let me know how to resolve this issue.
