Baltoi Ionut
Good evening everyone, I'm back with a problem with this telescopic loader.
The steering cylinder on my rear axle is leaking, so I decided to replace the gaskets, when I took it apart I found that it had been taken apart before, or even replaced entirely.
The problem is the following:
The turning modes of the wheels do not work for me.
From what I've read, those sensors on the cylinder must read the magnetic ring inside the cylinder.
I found the repair kit.
And that separate magnetic ring, the problem is that I don't know what that ring is or where it should be mounted.
Or if I still have it on my rod.
Does anyone know where it can be?
