Hammerhead
Hello,
It looks like both of my quick attach cylinders are frozen. The actuator button works fine, the hoses are good and there is hydraulic fluid movement, I can literally see the hose jerk when I actuate the button.
I removed them both today and cannot get either one to budge. And I mean no movement on the pistons. Drained out the hydraulic fluid and tried compressed air, nothing.
I tried putting a breaker in the eyelet on the piston and pulling the cylinder with it under my feet, not a fraction of an inch movement.
They do not leak and the seals look pretty good. The hydraulic fluid was clean that I drained out.
This is a 262C, 2008 model. It looks like the stamping on the hydraulic cylinders are from the same year. The model number on the cylinder is 192-2640 CNG L01. Cat Parts.com wants $422 EACH for these 8 inch long cylinders.
Does anyone know of a reputable rebuild vendor, or someplace I can obtain affordable aftermarket cylinders? There did not appear to be a rebuild kit for these.
Or, any other ideas to break these free?
Thank you for reading.
