Nathan Garner
After 6 months of trouble shooting, I am finally coming here to ask..
I bought a 955L 85J6408 with a 3304 78P874 engine this past spring. It has the Scroll type fuel injection pump. It was not running when I bought it, but looked to be in decent condition. Was told that it ran when it was parked 3 years before, but had a steering issue. The steering issue isn't my main concern right now. I believe to have that taken care of. The biggest problem I have right now is I can not get it started. I have replaced all fuel filters, blown the lines out, replaced a section of the fuel line because it was kinked, removed and inspected the plunger groups, replaced hand primer, taken the transfer pump apart to inspect (didn't see anything alarming, but also didn't take measurements to verify clearances), cleaned the pressure relief in the fuel pump. I double and triple check to make sure all air is bled out before trying to start. I am very much against using either on diesels, but I have tried it on this. If I spray a tiny bit in the intake, it'll hit off of that, but will die right afterwards. The fuel gauge is reading pretty low while cranking but I'm not sure if thats normal or not. If I crank for about 30 seconds, the fuel pressure will be about halfway up the "yellow" on the gauge. I'm getting fuel to the cylinders, but my thought is that it isn't enough pressure. I am getting white smoke out of the exhaust while cranking. Any ideas on what I can look for next?
FYI, pretty sure I have some glow plugs that are shot, because I'm only showing about a 10 amp draw while trying to heat them. I will replace them soon but I know that won't cause it to not start.
