AntonioRocha
Hello everyone, I gota a Cat 320c with am overheating problem, already changed thermostat, water pump, radiator... she works fine, but the temperature climbs. Did anyone had similar problem?
Nige check if he has the high ambient cooling group, the clutch can fail and they overheat.Do you have an infra red thermometer, or can you get hold of one..? If so then take the temperature of the hoses at the top and bottom of the radiator when the engine is overheating and post them here.
The water pump, thermostat, and radiator you changed. Were the components you installed to replace them new ones or used..?
