Evansebs
Hi everyone any help would be appreciated changed my fuel shut off solenoid and if i take the fuse out it still won’t shut down
Help please thank you
This one doesn’t have a rod its a small solenoid i put a new one in when i took the old one out the plunger thing was kinda stuck in there im wondering if something caught inside the thing the solenoid screws in to 279c2 kwb00798Is the fuel shutoff working? If somebody watches it does it move or try to move? Can you shut off the machine by manually working the shutoff rod?
I am not sure on your specific application, but on other Cat machines the fuse allows power to the solenoid, removing it will ensure the solenoid cannot function.
I couldn’t pull up are past chats so i had to start a different one and i put the new one in and it almost shuts down but won’t mabye debrie in it ?It baffles me as to why a poster who already has a 3-page thread going on the same problem for the same machine would suddenly create a new thread for the same problem............
279c2
Fuel shut off solenoid I replaced it but after it warms up it still won’t shutdown? Any suggestions kwb00798www.heavyequipmentforums.com
Thanks
Doesn’t have a shutoff rod should the plunger be able to move freely in side the thing it screws intoIs the fuel shutoff working? If somebody watches it does it move or try to move? Can you shut off the machine by manually working the shutoff rod?
Jow do you look at old threds?It baffles me as to why a poster who already has a 3-page thread going on the same problem for the same machine would suddenly create a new thread for the same problem............
279c2
Check your oil sensor wire that’s what was wrong with mine after checking everything.I have 2 420Eit backhoes. One has exact same symptom. Been like that for 15 years. Changed stop solenoid. Didn't fix it. Told it was a defect in the pump.
So, on mine, just turn it off and wait for it to peter out.
