cat0299dlhcl00546 continuous flow
wriggconst
IF the percentages are low and vary does that mean the roller switch is bad? Thanks Wayne
Chrisso
Diesel Mechanic
Providing your DMM readings are correct, yes.
273-9104 CONTROL GP-HANDLE -RH is the p/n you need.
It's amazingly expensive.
wriggconst
I guess it is expensive. I wish I could be sure that it is the problem. I would hate to spend 1k and not fix it. But if the numbers aren't right then that must be the problem. Thanks Wayne
