ippielb
I haven’t been on for a while, but doing some maintenance on the machine...
changed final drive oil.
Changed engine oil
Changed fuel filters
topped up pivot shafts
set track tension
the roller I put two winters ago I must not have tightened the bolts enough it walked out a bit and the rail was touching the edge so repositioned that.
Put the tilt cylinder back on
I propped up the loader arms with round bales. Curled the bucket back, took a tractor and pushed against it to support everything. Released the pressure off the hydraulics with machine off. Drained all the hydraulic fluid from the tank, then took off hydraulic lines To lift arms and nothing came out... the tilt cylinders were straight vertical so I was able to drain the barrels on those. I slowly took the bales away from under the loader arms to drop them and push all the oil out of the barrels... made a mess but it’s done.
now tomorrow all I gotta do is wiggle on the hoses, which will be a pain because lift cylinders are in the way now. And then fill up with hydraulic oil, rinse off all the oil mess, put the panels back on. And grease it.
I have 3 jobs lined up this week with the loader. And another job I have to set a time for.
Changed engine oil
set track tension
