Finally getting the moneys worth!
I have a carrier roller that has started to squeak. Curious if it’s worth it to replace the bearing, or just replace the whole roller. The whole assembly is $315+tax.
Only squeaks when I go backwards, forwards it’s quiet, had someone look for me and they say it wobbles a bit in reverse.
I’ll try that.Put a jack between track frame and rail, lift the rail from the roller and see if binding or excess play, look for oil or grease around the seal region as they will leak away the lube.
Had someone stand outside machine and check for me.Are you sure it's the carrier roller? Quiet FWD/Noisy REV can be an indication of idler problems.
The 955L's were quick and nimble... makes me smile just thinking about it.listen to farmerlund. with this many hours you can expect very burdensome repair bills. check out the 955L just a couple of threads below. if I wanted a loader that one would do it for me. no hydro trans, cab, even a winch on the back, which might get you out of a hole that a 973 would be out of sight in.
the PS trans is for sure a little slower than a hydro but it will hang in there way cheaper in the long run.
There seemed to be a whole cadre of hands who did that... it was faster I reckon, if you were loaded up with trucks. It always seemed a little on the abusive side to me particularly with the 77's. After you got the hang of it it wasn't too bad , slacking the throttle before the shift probably lost a second or so. Although I did have a little envy for the International hands and their deceleratorsYes they were, earlier ones were pretty well bulletproof. Had a customer years gone by would not decel to shift F-R would hand stand it on idlers or sprockets, that machine outlasted him. Believe it was a K though.
I actually just did this today, took me a 10lb box of rods. And about 8 hours. The shanks for the teeth have been built up before I can see. And the teeth themselves are worn open I can tell. I got them snug, but still a little bit of up play in each direction. 1/8” of play probably. Over time they’ll pound out the high spots and probably turn into 1/2” play I’m guessing. New pins and retainers are nice, I won’t be scared of losing teeth anymore. I was having serious problems with one pin wanting to come out, every time I’d push, roots would get between the blade segment and the tooth and push it out.Looking at post #309 it appears as though the centre tooth adapters are so worn I'm amazed the teeth stay on them. There is an obvious wear lip at the back end of each adapter where the teeth have been rubbing against it. It would appear that the adapters need some building up while you're at it with the welding machine on the bucket.
Ah well, the jobs done with 7014 now. I’m sure it will last as long as the teeth do. And then when I get new teeth i’ll Do 7018 or look into the hard facing. A guy at my work told me about hard facing and that it makes a ugly mess into blobs when it burns off the rod. I can’t say I’ve ever seen or used it.Are you using an old AC welder? 6014 works better on straight polarity and pushing into the puddle working them basically in fairly rapid circles helps the puddle to freeze before it falls away. I prefer 7018 as to ductile strength and better erosion resistance, for that matter hard facing may work as well for build up on those tooth supports.
