rmllarue91
980g 2kr1501 quad gauge and tach cluster inop.
They both self test but don't display info on et trans shows gear and direction but gear lever line on et says not available or something like that. But there's not a position sensor so I'm thinking that's calculated by trans or monitoring modules.....One code in monitoring system mid 30 cid 819 fmi 02. Main display not receiving back info... Ohms the pink yellow blue c413 c414 e708 to power ground and each other wiring seems good load tested grounds and main monitor power.
Quad gauge and tacho. Gauge group both maintain ground and 9 volts
Sensors voltage from main display stays at 8 volts what don't i know about this monitoring system yet thanks hef!
