Good morning,
So im having a bit of an issue with this dagone thing...
Cat IT28G 8CR00481
It previously on drifted down on the tilt. Now its drifting both ways.
So...when it was only drifting down i dug into it. Found that the relief valve were corroded almost in half. Replaced those and repacked one cylinder. It looked as if someone had been in there and had ground down the inside of the barrel. I told the boss the new packing kit may or may not hold on this thing but he said to continue. The other cylinder had catastrophic failure. Metal inside and destroyed. Replaced with a good used. Drained hydro and replaced filters, drained lines.
No more drift. Beautiful. Went on on a job for a few days...drift is back but as i said before now it drifts both ways. Could it be the cab control at this point? i find it unlikely that both cylinders failed again although i was already questioning the one...
Cat IT28G 8CR00481
