The next component of interest is the main control valve. (Front view)
(Back view).
There's several things going on in here including neutral start function, braking and and couple of pressure controls. What interests us though is.......
This component with the two O rings. It's the venturi. It takes the flow from the charge pump and (as we all know from high school physics class, duuh) the pressure at a venturi is lower than the pressure upstream of the venturi and the faster the flow, the lower the pressure at the venturi.
This provides us with two pressures. The difference between the pressures (delta pressure) is directly proportional to the flow and, because the flow is provided by the charge pump, the delta pressure is directly proportional to the engine speed.
BTW, apologies to any physicists reading. I'm only a diesel fitter and if my take on any of the fundamentals is way off, please let me know.
(Back view).
