Cat d9h relief valve poped off why?
fiat41b
pawnee il.
Ok the title seems right
we have a d9h its on a job and the relief valve for the radiator pops off
its sat for 6mth thru the winter just dry enough now to work it where its located
I seen this before I just let it do its thing and settle down, i only did it a couple times for me and i have put over 300 hrs on it
I just did 37 hrs on it now i have a guy on it and he is telling me its spuing out antifreeze thru the relief
i never have to add oil or coolant to this tractor however i did top off the radiator overfilled just before he got on it
he is 500 miles from me i told him to see if bubbles are coming up and out he said it looks only like a little foam such as when you run you faucet in the sink
I have a box of receipts on this tractor
newer engine rebuild and new radiator make that a second new as 1st was damaged in land clearing stick stuck it.
that was over 300 hrs ago.
any suggestions oh and its not over heating and no oil in radiator or coolant in engine
My 9H's are all too far away to look so I'm guessing:D
Does this have a reservoir? or just the radiator and cap? If there's no reservoir, then the top tank of the radiator is the expansion space and you can't fill it all the way to the top, typically you want the level an inch down from the bottom of the neck.
John C.
Those machine have a great big radiator cap and not a small one like a car. There is a relief valve right on top of the radiator with a little hole out the side. You can take it apart and replace the parts inside. A lot of time they are just old and never had any attention.
kshansen
Central New York, USA
fiat41b
pawnee il.
I fired it up and took it for a short test run, I have a heat gun and have shot it all around and it was 148 to 190 but mostly below
that's shooting all the radiator, all the different temps are from top to bottom and the head - thermostat housing and the sending unit areas
The lower engine block was 210 maybe a 214
Here is what the gauge was reading its just a color gauge
green upper green upper yellow then red I ran it for 45 minutes and it was reading close to the yellow we do blow the radiator out with a air compressor
I was not running it real hard never have to as its just cutting trees with a v/sheer blade
I parked it with it running and broke the radiator cap loose slowly as it had pressure and it sprayed out with suds-foam then I had the helper open the throttle it all lowered and was flowing but I was not getting big type pop up bubbles just high flow and foam .
Yesterday I talked to a old mech but he does not go out and turn wrenches any more on the job but he knows these old 9's a bit
he told me to go and warm it up with the cap off and when it foams put some of that foam on a sheet of paper to ck for oil that takes a while, I did no sign of oil
he said it could be a number of things from the oil cooler around injectors heads and head gasket ect.
I hate to tear it all down chasing a unknown
yesterday while I did this I filled it just a little bit below the bottom of the neck with added water cranked it up for a good 1/2 hr low and high idle
and got the thermo to open the temp was up in the mid green I unscrewed the cap and it had some pressure pushed some out not much and there was no foam yet and no sign of bubbles or air popping up
however the coolant has risen to the top of the neck I shut it off as there was no more I could do it keep rising very very slow so maybe it was expanding I know thing get hotter when you turn them off.
oh yea I opened up the crank fill and there is no sign of milky looking oil at all in or around the cap
the engine does not smoke at all
Vetech63
Oklahoma
The hottest point on your system will be at the thermostat housing and the inlet at the top of your radiator. You need to compare your heat gun reading with your dash gauge to have an accurate comparison. Your temp should drop 30 - 35 degrees from the top of the radiator to the inlet of the water pump on average.
John C.
I've never seen a dozer drop that much in temperature. Usually was lucky to get twelve or fifteen degrees between thermostat housing and radiator outlet.
catman13
oregon usa
pull the cap off and warm it up and run it at 1/2 throttle and smell the radiator and see if it smells like exhaust,
my d5h started running warm had some small bubbles in the radiator and it looked like it had steam coming out of it but it had a blue look to it and I smelled it and it was exhaust , had tiny crack in the head gasket , new gasket and the heating problem was fixed
John's right. The rule of thumb for a conventional radiator like this one is around 15 degrees temperature difference between the top tank and the bottom tank if everything is in good working order.
Mobiltech
Sask.
There is a chance it’s pressurizing from a compression leak but I would bet if you quit overfilling or adding coolant it will eventually find its happy place and go back to just releasing air out of the relief valve. From this point the coolant level will stop going down and as long as it’s not heating it will be fine.
kshansen
I was thinking along the same lines. If filled right to the top there is no place to go but out the overflow.
fiat41b
pawnee il.
Ok but where could the suds be coming from ? I don't see constant uprising bubbles with it warmed up and idling with the cap off
maybe i should flush it with a garden hose till I see no antifreeze then run it hard and recheck to see if I see for foamy crap after I top it off with water and power wash the radiator, as I know all that coolant ran down and the fan most likely blew it thru the radiator and its really dusty out there.
probably get a new thermostat also
what should the rpms be on this d9h high idle 1300?
Mobiltech
Sask.
Ok but where could the suds be coming from ? I don't see constant uprising bubbles with it warmed up and idling with the cap ?
I don’t think you’ll see rising bubbles through the cap. Any air coming from the engine will come through the top rad hose.
fiat41b
pawnee il.
I guess that's why they want you to fill it up to the top of the neck as it would be the only place air could escape
the cap is off to the side and the top hose is about in the middle right where the relief is
I think I will try the jug of that exhaust leak fluid as pictured above
