Cat D5N.
I have 2005 model LGP(86kw/115hp) and it is a real good unit with plenty of push, comfortable to operate and to date no breakdowns. It's only done 2600hrs. Mine is set up for forestry/scrub and wildfire work with a full canopy over the cab, bonnet and rippers, integrated green and amber flashing LEDs(green has a much greater penetration in smoke), tree pushing spear, set of Komatsu D65 rippers and PAT blade. total weight 17250kg. I have both 30" LGP and 20" standard grousers for it. I believe they discontinued the D5 high track as the D6 had some models downrated to nearly the same HP. I think also they regarded the D5 size as a finishing size dozer which the high track configuration is not the best at because the distance between the dead axel and the equaliser bar is so close compared to an oval track. In my opinion this can lead the hight track models to start wallowing up and down which once they start it is quite difficult to correct. I know it is a lot easier to do a nice level road in the bush with my old D4E than with my D5N especially if you are trying to do a hard cut. Of course this may be just my bad handling of the D5N - but I have done a few hours on dozers. As far as operator comfort, serviceability, manuverability, balance, working on slope, in wet slop, pushing dirt and timber the high track wins' hands down'. If you have the time there is not much you won't be able to achieve with the D5N
