Dave303223
So I got my brand new 1993 D5c (SN 6pj00785) home and, as I do, started tinkering with it between clearing some land. I knew it had a pretty bad leak from the trans area but got it at the right price thinking I'd fix it as a winter project then something weird happened. The fellow I got it from said he ran AW32 in everything but the engine and I'm a little picky for spec so changed to TO-4 spec in the Trans and correct Hydraulic in the hydraulics. When I put the new fluid in it leaked like a sieve when running, I worked the dozer about three hours and put it away. Next day I was determined to find the leak, topped it up (didn't take alot) and pulled panels and sprayed it down with cleaner. Got it warm and started looking, a tiny run was coming from around the Right turn brake valve and that was it!
Been working it for two days and still no real leaks, What the heck?? Could just running the right fluid fix a seal leak, swell the seals or lube them? I keep hoping its not a fluke, anyone see anything like that??
Dave
Dave
