Cat d5c bore spec
Discussion in 'Dozers' started by Tyler d4c, Dec 4, 2019.
  1. Tyler d4c
    Tyler d4c Senior Member
    Mar 3, 2016
    273
    Salix Pa
    I need the spec for the barrel end bore for the spherical bearing in the tilt cylinder. I cant seem to locate it 7ps prefix. Thanks for the help
  2. Nige
    Nige Senior Member
    14,840
    You mean this one..?
  3. Tyler d4c
    Mar 3, 2016
    273
    Salix Pa
  4. Nige
    Nige Senior Member
    14,840
    I can't find a spec for it. It'll be buried somewhere in a dealer-only rebuild spec or in a factory engineering drawing.
    Ballpark figure. Get hold of a new 4D-0298 spherical bearing and measure the outside diameter with a micrometer. Rebuild the bearing bore to that measurement MINUS about 0.001" per inch of outside diameter of the bearing.
    So for example if the bearing measures 4.000" O/D, machine the bore to 4.000 - (4 x 0.001) = 3.996".
    You'll need some dry ice or similar to shrink the new bearing in order to get it in.
    Sorry that's the best I can come up with.
  5. Tyler d4c
    Mar 3, 2016
    273
    Salix Pa
    That's the plan was just trying to get ahead of the 8 ball. Thanks anyhow.
  6. kshansen
    kshansen Senior Member
    Mar 11, 2012
    8,133
    Central New York, USA
    That's a good plan but I would add that many of those spherical bearings are assembled by "cracking" the outer ring on one side to let it spread a bit to allow the inner section to pop in. So when measuring the O.D. for the boring of the housing I would be tempted to put a heavy-duty hose clamp around the outside and tighten it good to see if the measurement changes. Might be a little fussy but for the time it takes not a big deal.
